'99 D2 Wont Start!
Old Dec 16, 2009 | 11:16 AM
mjhebert's Avatar
4th Gear
Default '99 D2 Wont Start!
Got in my D2 this morning and the hazard lights were blinking. Tried to start. Lights and radio come one, but it will not turn over. ALternator is only a couple of months old. Could it be the solenoid?
Thanks,
Mike
Old Dec 16, 2009 | 11:45 AM
Reset your alarm and your inerita switch, one of them will fix it.
Old Dec 16, 2009 | 04:17 PM
mjhebert's Avatar
4th Gear
Default No luck.
Mike,
I assume resetting the Inertia Switch and the Alarm Switch is simply pressing them - which I did. The car still won't start. Battery is fully charged. Fuses all good. Alternator new.
Any other suggestions?
Mike
Old Dec 16, 2009 | 08:37 PM
mjhebert's Avatar
4th Gear
Default Fixed
Well, resetting the Inertia and Alarm switches didn't fix the problem. I found a related post that recommended locking and unlocking the drivers side door three consecutive times. I did it and Voila!, it started. What does this mean? Was the starter relay interrupt tripped? My passenger side door lock does not lock anymore. I may have locked the other doors with the Key Fob and inadvertantly tripped the alarm, disabiling the Starter Relay.
Am I close?
Thanks,
Mike
Old Aug 25, 2012 | 03:05 PM
cptshanman's Avatar
Default Back from Iraq, DII been sitting for over a year in storage
Hi guys, I think this thread might be related to a problem I have. I have been trying to start my DII that has been parked since I went to Iraq last year in April. I thought it was the battery so bought a new battery. Plugged it in and get nothing but power to electronics and incessantly blinking hazard lights. Do you guys think I have a similar problem? The truck has been in outside storage.
If you think it is the inertia and alarm thingy...how do I reset that exactly? Thanks guys. You guys are always here for me.
Shannon
Old Aug 25, 2012 | 06:42 PM
Did all this start after you opened the hood and swapped out battery? If so, the truck "woke up" and thought the barn door was open, so the alarm and immobilzation kick in. The inertia switch looks like an ice cube size gizmo on the wire wall, press button on top to reset. You can try the lock/unloc multipl times, if you have a key fob you can try that also. Alwasy a good idea on a dead battery situation before jumping or new battery to hold down the hood alarm switch.
Old Aug 25, 2012 | 07:02 PM
cptshanman's Avatar
Unfortunately, I didn't know about this prior. I got back and battery was dead, tried jumping it and that's when the hazard light thing started. I thought it was just too dead to go on (the battery) and bought another...but after changing the same thing happened. I'll try what you mentioned next time I go out there (it is in the post storage lot right now). Thank you for the advice!
disconic
Jun 4, 2016 02:57 AM
gustav23
Dec 15, 2011 01:12 PM
armyeng
Mar 8, 2011 05:58 PM
jonsimon
Jan 29, 2007 01:55 PM
