AC condenser
Old Jul 27, 2010 | 04:27 PM
toad2's Avatar
Default AC condenser
Heading to the garage to change out the AC condenser and change the coolant in the coolant system. The beers cold and its a beautiful night up here in the Maritimes! Wish me luck. I'll check in later to see if there's any pointers. Cheers.
Old Jul 27, 2010 | 06:33 PM
Good luck!!
toad2's Avatar
2 beers and 2 hrs later i've got the old condenser out. pita job but i'll stay at it.
Old Jul 27, 2010 | 06:50 PM
Keep us posted.
Old Jul 27, 2010 | 08:22 PM
lordmorpheus's Avatar
Don't you just love all of the ducting? Seems like everything under the hood has ducts, heat shields, or vent tubes...
1 beer an hour makes for good work.
Old Jul 27, 2010 | 09:30 PM
toad2's Avatar
ya seems like there is always one more piece that has to come off. Anyway, pretty well done the condenser, just need a couple new o-rings tomorrow.
I drained the rad and or cooling system but there didn't seem to be a lot of coolant. There must be more in the engine I can get by taking a hose off the block or water pump, but that was some bad looking coolant in there. I am glad I changed it.
That's it for tonite, back at it in the mornin'.
Old Jul 28, 2010 | 10:05 PM
toad2's Avatar
So, just an update. Changed condenser, changed coolant and semi assembled. I went to buddys shop to charge the ac and we had a line leak by one of the body bolts. i ordered the line from AB and will try again. We are considerably more than 1 beer an hour tonight. i think i love my disco !
Old Jul 31, 2010 | 07:55 PM
Rovin4life's Avatar
Did you bother to diagnose the problem or just throw parts at it. Because with some ac dye and a full charge you can see the problem before throwing parts at it.
Old Aug 1, 2010 | 07:15 AM
toad2's Avatar
yea, we dyed it and there was a major hole in the condenser. Swapped it out and dyed it again and found a small leak in a line.
Old Aug 20, 2010 | 02:25 PM
toad2's Avatar
So, just a late update. Got my new line from AB and installed. Got my ac system charged up and now we have ice cold air !! WooHoo
aemnky606
Jul 6, 2024 10:53 PM
EstorilM
Oct 8, 2019 08:26 AM
ibyrover98
Mar 17, 2010 11:38 PM
MarvelVT
Jun 9, 2009 03:33 PM
jmt
Jan 14, 2008 05:01 PM
