Adding sunroofs to a 99 DII
Old May 2, 2010 | 09:23 AM
range_time's Avatar
Default Adding sunroofs to a 99 DII
My DII did not come with any sunroofs and i have to say i really like the look of them. Has anyone added a set from another disco? I dont want any aftermarket ones.. i really like the look and function of the factory set up.
I see a few for sale on line and was thinking about getting up some courage and a jigsaw and getting to work. If someone has done this and has any tips that would be magic!
Thanks
Dave
Old May 2, 2010 | 09:41 AM
I am not sure if the roof frame has the areas cut out to install sun roofs. That would be the main draw back other them wiring.
Old May 2, 2010 | 11:19 AM
GARovee's Avatar
I have a 03 Disco S. A previous owner installed aftermarket sunroofs. Used the stock switch locations. Everything works great and looks great. I think I actually like it better than the factory sun roofs because instead of those cheesey pull across shades I have a solid vented slide away cover like most sun roofs use that reused the interior headliner so it matches. I wouldn't spend all that time doing to the install and using those stupid sliding shade things.
Old May 2, 2010 | 12:26 PM
tweakrover's Avatar
your title to this thread should be "thank God I don't have sunroofs"
Old May 2, 2010 | 02:43 PM
audiS4S6's Avatar
It's a LR, of course they are cheesey - that's what makes it a LR, no?
Your install sounds nice but high-buck. The install of these in a '99 Disco may not make a lot of sense - likely costing a large percentage of the value of the truck.
Range Time - my humble opinion is live without them. If you can do the install yourself and really want them - try it I guess. If you are going to have to pay to have it done - I'd pass. Holes in roofs aren't generally a good idea.
Old May 2, 2010 | 03:06 PM
Danny Lee 97 Disco's Avatar
You could probably buy another Discovery for about what you would spend putting sunroofs in your current one.
I had a MB 420 SEL that had a solid metal very large sunroof, I really liked it.
I have also seen a local Surburban running around with a slightly raised roof with Alpine Windows and a very nice MoonRoof. I would do a custom job before i would cut up a good Disco to put in those tiny twin sunroofs.
Old May 2, 2010 | 03:26 PM
range_time's Avatar
I get a pair of sunroofs (compete with motors and harness) from a DII shipped to me for about $350 (the pair) The plan is to do my own work as it was the fun of doing the project that i really fancied.
The other great thing about having sunroofs is i know i wont get water in them, it only rains 2x a year here and for all of 10 min so its just not an issue.
I had thought about using 1/4 aluminum plate and not glass just to be a bit different but I'll see what i can get my hands on.
Thanks for the input and I'll let you know what i decide.
Dave
Old May 2, 2010 | 03:34 PM
audiS4S6's Avatar
just remember - measure twice, cut once!
If you pull the headliner (that probably needs to be recovered anyway) you will see the basic location of the sunroof positions.
prairie boy
Feb 6, 2021 10:17 AM
ProRiderRoadKing
Mar 19, 2014 04:10 PM
minimad666
Jun 10, 2012 10:05 AM
spence426
Oct 24, 2008 11:15 PM
johnkbl
Apr 16, 2007 02:39 PM
