Airbag Removal
Airbag Removal
When I get home I am planning on replacing the cruise control switches on the steering wheel because I believe it is bad. I was looking at the RAVE manual and it said to remove the airbag module it take a tamper proof hex wrench. Does anyone know what size Hex the bolt are? Has anyone pulled the steering wheel airbag module? Someone has to have done this at some point.
RE: Airbag Removal
I was surprised when RAVE only said 20 minutes between disconnecting the battery and starting work. Fortunately the bolts are on the back side of the wheel so I don't think I have to worry about the driver going through my brain. And it would be a 1 in 10,000,000 shot to hit that small of a target. I was planning on an hour of the battery being disconnected before I start. I have enough other stuff to do that the time won't be wasted.
tfenske
07-12-2006 04:58 PM
michael
11-15-2005 01:15 PM
