Airbag Removal
Old Jan 15, 2009 | 09:27 PM
AK Rover's Avatar
Default Airbag Removal
When I get home I am planning on replacing the cruise control switches on the steering wheel because I believe it is bad. I was looking at the RAVE manual and it said to remove the airbag module it take a tamper proof hex wrench. Does anyone know what size Hex the bolt are? Has anyone pulled the steering wheel airbag module? Someone has to have done this at some point.
Old Jan 15, 2009 | 09:38 PM
Default RE: Airbag Removal
I have never done it but you MUST disconnect the battery for no less than 1 hour before starting work, it can go off in your face and drive that hex head screw driver through your brain.
We dont need to loose any more forum members.
Old Jan 15, 2009 | 09:47 PM
AK Rover's Avatar
I was surprised when RAVE only said 20 minutes between disconnecting the battery and starting work. Fortunately the bolts are on the back side of the wheel so I don't think I have to worry about the driver going through my brain. And it would be a 1 in 10,000,000 shot to hit that small of a target. I was planning on an hour of the battery being disconnected before I start. I have enough other stuff to do that the time won't be wasted.
Old Jan 15, 2009 | 09:52 PM
Well I didnt want to say it, but since you did...it is a small target.
I say a hour just to be safe.
Old Jan 15, 2009 | 09:56 PM
AK Rover's Avatar
I figured I would save you the agony of trying to hold it in. I knew the thought was there.
Old Jan 15, 2009 | 10:42 PM
lrd2's Avatar
i have a question about air bags if i were to change my steering wheel should i use the same air bag that i currently have or use the same one that comes with the steering wheel?
Old Jan 15, 2009 | 10:45 PM
sloppyjoe's Avatar
just hit the front of the rover with a sledgehammer until the airbag pops and then use a utility knife to cut it off,,,,
AK Rover's Avatar
Are you talking about a factory replacement steering wheel or an aftermarket wheel? If it's a factory steering wheel you can use your original airbag module and save or sell the one that comes with the wheel.
Old Jan 15, 2009 | 11:48 PM
lrd2's Avatar
yea factory wheel i want to change mine because the top of the wheel is faded into a dark black when the rest of the wheel is tan colored
faheemf1
21
Feb 29, 2012 08:41 PM
captainkent
Mar 5, 2007 08:08 PM
edjlong
Oct 2, 2006 07:25 AM
tfenske
Jul 12, 2006 04:58 PM
michael
Nov 15, 2005 01:15 PM
