Airbag removal
Old Oct 3, 2017 | 09:53 PM
longtallsally's Avatar
Default Airbag removal
So I'm finally going to resolve all the little issues I have for the moment and register the Disco (jeez, about a friggin year later no less...).
Anyway part of the inspection is a quick toot of the horn. Well I have the seemingly common spring failure. However, I can't seem to do the repair without having to pull the airbag- based on the replacement parts i've got.
I watched the Atlantic British video on replacing the spring, but the parts I have and what need to go in are different. Anyway, I wanted to pull the airbag anyway in helping with the diagnosis of the cruise control system.
GETTING TO MY POINT, I buggered one of the torx screws to get the airbag off. Any ideas on getting an easy out bit in there? I'm thinking I'll just get a Harbor Fail cheapo close quarters drill with the bit in there to go after it. If I kill the whole thing, I can get another wheel (already wrapped mine in paracord) and airbag for under $150...
Old Oct 3, 2017 | 10:25 PM
LR03NJ's Avatar
This link might help. I did my steering wheel not too long ago.
https://landroverforums.com/forum/di...removal-85061/
Old Oct 3, 2017 | 10:37 PM
Thanks for the prompt response and thread reference.
I've seen the RAVE portions and watched the video previously. So I know how to do it, but I screwed up and used a torx wrench one size too small on one of the screws and stripped in.
Bottom line, how do I fix such a colossal mistake? The easy out is best I can come up with...
Old Oct 3, 2017 | 10:50 PM
LR03NJ's Avatar
How about this
Amazon Amazon
Old Oct 4, 2017 | 07:47 AM
Yeah I've got a set of those, but may have to order what you've got based on how deep the screw is in there.
I've not messed with it in a bit, but I need to see what kind of access I have to get in there...
Old Oct 4, 2017 | 08:51 AM
number9's Avatar
You can simply drill the screw head off. Once module removed should be able to remove remainder of screw more easily.
Old Oct 4, 2017 | 10:06 AM
mollusc's Avatar
Drilling the head would be my suggested approach too, but getting a drill in there might be pretty tight.
What is the spring failure? One of my buttons was non-functional when I got my truck because a leg was broken off it and the spring was missing, but I was able to replace all of that from the front without having to dig into anything.
faheemf1
21
Feb 29, 2012 08:41 PM
AK Rover
Jan 15, 2009 11:48 PM
edjlong
Oct 2, 2006 07:25 AM
tfenske
Jul 12, 2006 04:58 PM
michael
Nov 15, 2005 01:15 PM
