All D2 Trannys Fit an 03 D2?
Old Sep 7, 2014 | 09:08 PM
Dirtnap's Avatar
Default All D2 Trannys Fit an 03 D2?
Wife is having major tranny leak while traveling, so Im trying to get an idea of compatibility. Do all D2 trannys fit an 03?
She said she saw smoke out the rear window and pulled over immedialely. Got out to have a look and fluid over the rear end. Turned it back on and put it into drive and wouldnt really go, so stopped and called aaa. Tow guy thought it was tranny fluid. So preparing for the worst.
Thanks
Brian
Old Sep 7, 2014 | 09:25 PM
abran's Avatar
The 03 has a beefier trans to handle the 4.6 motor.
My wife has an 04 with a O4 trans and torque converter but with a 4.0 motor from and 02.
Doesn't directly answer your question, but I imagine it could go the other way.
Old Sep 7, 2014 | 09:26 PM
abran's Avatar
If you are near CA I have an 03 trans I could sell you.
Old Sep 11, 2014 | 08:18 AM
DustyLBottoms's Avatar
No, it's not a direct fit. The transmission on the 2003/2004 has beefier internals, and thus longer than the earlier D2's. This means that the transfer case is further back, which requires a longer front proper shaft.
Old Sep 11, 2014 | 09:55 AM
abran's Avatar
Rave manual actually notes the exact length difference, I can't remember what it was but not that extreme. At max you could buy a prop shaft spacer from Rovers North and be done with it.
Old Sep 11, 2014 | 10:25 AM
It's 15mm.
Old Sep 11, 2014 | 10:47 AM
ZGPhoto's Avatar
^that is accurate
That being said, they are pretty much interchangeable, and all aftermarket shafts fit any year.
Old Sep 11, 2014 | 11:35 AM
abran's Avatar
Yeah, I was going to say that that is .6". I noticed that lucky8 sells their shaft as interchangeable for all years. Installed it in an 03' with no issues, but was a little concerned.
DiscoRover007
Jul 14, 2020 12:54 PM
Dirtnap
Sep 7, 2014 08:50 PM
gulfcoastgorilla
Aug 13, 2012 04:58 PM
ljdiscovery
Nov 15, 2011 11:07 PM
polargirl0000
Aug 8, 2010 11:45 AM
