Antifreeze leaking around the throttle body?
On the driver’s side I can see it dripping from the throttle body onto the engine. I see there are two small hoses and replaced one that looked suspect but it’s still dripping away. There seems to be a small cast plate that both hoses connect to. Could that plate have a hole or crack in it? Anyone know what that part is called and if there available.
http://www.roverparts.com/Parts/MGM000010KG.cfm
Throttle plate kit. buy two small hose clamps as well.
replace it or bypass it...
You can replace it or bypass it if you live wher its hot most of the time....
easy fix...
Chris
firstcoast
03-08-2009 01:01 PM
