Any experience with these power steering pumps?
Old Jan 30, 2026 | 05:38 PM
  #21
Best4x4's Avatar
I've personally noticed D2 PS systems don't seem to hold up to the older D1 PS system pump wise. Pumps themselves are nearly identical minus the 1 rubber line has a different angled nipple to the reservoir return line. The main difference is the D2 uses PS Fluid and the D1 system uses Dex ATF. I think the older RRC/D1/Defender setup is more robust. The boxes are prone to leak, but the Lucas PS Additive usually fixes it with very good results unless the box seals are completely trashed.
Old Jan 30, 2026 | 07:29 PM
  #22
Harvlr's Avatar
https://www.ebay.ca/itm/265041156540
I'm pretty sure this is the kit I used. IIRC, I did mine because it was leaking, but I don't remember for sure.
If you do it, the only risky part is that there are a couple of tiny parts that I wasn't aware of and was lucky I didn't lose them when I dunked it in the Varsol tank to clean it.
Old Jan 30, 2026 | 11:03 PM
  #23
CharminULTRA's Avatar
Originally Posted by whowa004
Thought about going to an electric pump? Having gone through quite a few as well as struggling to turn the 35s on my classic when wheeling at times has me looking at switching to one of the electric options (dodge or volvo I think depending on if you want a horizontal or vertical pump)
I'm also planning on an electric swap. The controllers are cheap, and I found a used Volvo pump on FB Marketplace for less than $100.
Old Jan 31, 2026 | 06:14 PM
  #24
AjjayS's Avatar
Originally Posted by Brandon318
No they hardly ever fail. My original pump failed in 2021 via the spindle coming loose and shredding the belt. I've never heard of it happening to any other disco though. That set off a long and never-ending journey of finding a replacement pump that wasn't either DOA or noisy. I'm on my sixth pump and am just settling for noisy for now. If they "fail" it's just because of a gasket leak usually due to heat cycling.
Appreciate the response, I'll keep in tune with your thread in case you find a good new unit, I will keep my noisy one until it dies
Old Feb 1, 2026 | 11:13 AM
  #25
Brandon318's Avatar
Update - got a notification from Rock Auto that an AAE is in stock, so jumped on that and will report back when it's installed what the outcome is. Maybe lucky #7 will be the pump that actually sticks around.
davidinNJ
Apr 18, 2024 05:56 PM
zski128
Sep 26, 2021 05:25 PM
Brandon318
Jun 23, 2021 01:45 AM
woodchip2bert
Mar 19, 2020 03:29 AM
kpl1228
Dec 6, 2010 11:08 AM
