Any secrets to removing the crankshaft pulley?
Man I was late to the party huh?
You could have put your breaker bar on the crank pulley nut and put a piece of pipe on it to make it long enough to wedge against the floor.
Then tapped the ignition key once or twice and she would have came right loose.
You would have let the starter do all of the work.
You pull the fuel pump fuse to make sure she does not start.
walkingzach
02-22-2015 09:40 PM
