ARP studs pulled my threads
Old Apr 25, 2023 | 09:18 PM
  #31
Harvlr's Avatar
I know there are two very different opinions on TTY bolts, with very experienced and knowledgeable people on both sides. My understanding of TTY bolts is that the whole reason behind them is even clamping, even at varying engine temperatures. Once they are in the “stretch “ mode they stay at about the same tension. While you do want to be careful to turn them the correct number of degrees, I don’t think it’s necessarily that critical, for the above reason. This argument has probably been beat to death though.
Old Apr 25, 2023 | 10:58 PM
  #32
Tony Luna's Avatar
Yeah…
I’m sticking w studs.
BTW, free set of ARP studs for whoever wants to pay for shipping.
Old Apr 26, 2023 | 10:04 AM
  #33
dswilly's Avatar
I am not an expert, just tracking this discussion. It appears that "stretch" is not exclusive to the bolts, only different in how it happens.
Some info here -
https://www.thomasnet.com/articles/h...ad-stud-bolts/
Old Apr 26, 2023 | 09:09 PM
  #34
Harvlr's Avatar
That’s a good article. When he writes about head bolts, he doesn’t indicate that he’s talking about TTY bolts, which is definitely different. Maybe it’s assumed to be TTY, but older vehicles didn’t use TTY bolts for their heads.
Old May 1, 2023 | 03:41 PM
  #35
RoverMasterTech's Avatar
TTY is better for non forced induction. Way better for layman installation. Basically no error to be made in installation. The bolt gets to max clamping force and then starts stretching. You can turn it 100 degrees more and its the same clamping force. ARP are for forced induction, when the power of the explosion in the cylinder can actually stretch the bolts and lift the head. Head studs are also used for applications where you are going to have the head off a lot.
Old May 1, 2023 | 05:45 PM
  #36
Best4x4's Avatar
I've installed ARP studs on plenty of LR V8's with zero issues. I'm running them on my 95 D1 with a 4.6L GEMS V8. It all comes down to proper installation/prep IMHO.
Old May 17, 2023 | 02:26 PM
  #37
Mr.Baobao's Avatar
5th Gear
Originally Posted by XRAD
That sucks. Block threads were probably already damaged before you got in there. When I put in my ARP studs, I hand tighten them w/allen wrench until they bottom out, then back off 1/2-3/4 turn. I do not leave them bottomed out, and no lube on the block side of the studs at all. ARP lube for head side of studs as recommended....
agree with above. Your block will be fine with coils, but have a machine shop do them. unless you have a way to tap dead on...and i would suggest a taper tap to start, and then switch to a blind tap. Also, driving in the coils can be a real pain if they bind half way in.....
This is the way...you have to back them off a bit, just watched a recent video on ARPs site explaining this. I did the exact same thing with success. There will always be some stud rotation when you put the nuts on,if you snug the stud, it will turn an additional 1/2 to 3/4 turn during assembly, this is what strips the threads once you add torque.
Roby466
Mar 14, 2021 06:21 AM
gulfdisco
Apr 11, 2020 03:03 PM
gulfdisco
Jan 31, 2017 08:26 AM
wyrdvans
Jan 9, 2015 09:06 AM
gbob
Dec 2, 2014 01:43 PM
