Assorted bolt and nut kit for Disco 2
Old Mar 21, 2020 | 10:06 PM
mr. choodles's Avatar
Default Assorted bolt and nut kit for Disco 2
Hey guys,
I am rebuilding the interior and a few pozidriv bots--the ones that hold the center console--got stripped. Also, some the nuts are quite old and I am thinking of replace those components. Here is the question: where do I find suitable alternatives? I don't feel like hunting for each nut and bolt. Where would I find the specs? Are there any assorted third-party kits that will be suitable for Disco 2?
By the way, if you have Tuff Rok Cubby Safe could you please let me know the specs for the bolts that came w it? It will solve a few issues ;-)
Thank you!
Old Mar 21, 2020 | 10:22 PM
More specifically, does anyone know the thread spec of this cage nut that keeps the console mounted to the body? There are four of these nuts two up front below the transfer case lever and two in the cubby.
Old Mar 22, 2020 | 10:56 AM
Alex_M's Avatar
If those cage nuts are ok I wouldn't change them. As for the rest, your local big box hardware store or Fastenal should have whatever you need. I'd just take in the bolts you plan to replace and match them up. They'll all be metric, of course.
Old Mar 22, 2020 | 12:18 PM
So cage nuts are a problem indeed. I was able to match the bolts and I'll do a write up in a separate thread. So do these cage nuts come with LR # ?
Old Mar 22, 2020 | 12:29 PM
OverRover's Avatar
so do these cage nuts come with lr # ?
It looks like > NK105061
Bolt/Screw > SE105164L
Old Mar 22, 2020 | 01:54 PM
Many thanks! Shor-term approach: soak what I got, remove rust, lube and see what's up.
Old Mar 22, 2020 | 06:16 PM
Brandon318's Avatar
I got a bunch of them from Rovers North a few months ago when I was doing a big interior clean and fix project.
MrScruff
Jan 15, 2020 09:15 PM
ammonation
Aug 30, 2015 08:55 AM
Francopacks
Aug 10, 2012 08:39 PM
penniwb
Jan 29, 2010 06:02 PM
Darover
Nov 5, 2008 02:36 PM
