back to square 1 again with 2 cylinders misfiring...
Old Nov 14, 2012 | 05:14 PM
me 2's Avatar
Default stuff
Thanks man, on top of this my clutch finally took a dump in my Mini so now i have 2 projects...
The metal loud fast tapping sound in my opinion sounds like a valve or a piston but not sure. I think its to loud and steady to be arcing. Prob is im afraid to run it long to investigate more.
Old Nov 15, 2012 | 05:10 AM
jfall's Avatar
Loud tapping?
After say a few miles drive?
Right in the middle of the engine?
Sounds like a liner for 2,3,4,5 is loose
Old Nov 15, 2012 | 07:52 AM
or this..... did you account for all tools and bolts?
can you take out the plugs and turn it by wrench? Or do a compression test (using starter, not the wrench)?
Attached Thumbnails back to square 1 again with 2 cylinders misfiring...-100_2422.jpg
Old Nov 15, 2012 | 11:03 AM
me 2's Avatar
Default stuff
Had it towed to a shop and they found that it is most likely a push rod out of place or bent. If so, what usually causes this?
Old Nov 15, 2012 | 07:15 PM
0304Disco's Avatar
If you broke a valve spring it could cause the push rod to not seat on the lifter or bend the push rod. You really won't know until you start breaking it down.
DavC
Jul 31, 2015 03:47 PM
ggray
Aug 9, 2013 09:36 AM
caerb
Jan 12, 2013 01:54 PM
Savannah Buzz
Apr 1, 2012 12:26 PM
grussell
Aug 23, 2009 09:33 PM
