Back Sunroof won't work
![Thumbs down](https://landroverforums.com/forum/images/icons/icon13.gif)
Hi everyone,
On my DII 04 the back sunroof does not open. I'm not sure why because the front sunroof opens and operates perfectly fine. Sometime this summer I took the entire headliner off and sealed the leaky roof that these DII's had but didn't bother to work on the back sunroof at the time. What do you suggest might be the issue?
Thanks so much and hope everyone is enjoying the holiday season!
There is a little square plug that can be popped out of the plastic trim just a few inches from the switch. Once it is popped out you can put a small allen wrench in the motor shaft (forgot the size), can turn the motor by hand. If it doesn't turn, the problem is the motor. Pop the switch out and there is a screw under it, pull the trim around the sunroof and you can drop the headliner enough to remove the motor.
If it does turn, could be switch, relay, or control module.
Good luck.
Good luck.
dasherman (12-29-2017)
akilbrid
08-20-2017 12:18 AM
dmm698
08-28-2007 06:37 AM
