Back Sunroof won't work
Old Dec 29, 2017 | 09:54 AM
dasherman's Avatar
Thumbs down Back Sunroof won't work
Hi everyone,
On my DII 04 the back sunroof does not open. I'm not sure why because the front sunroof opens and operates perfectly fine. Sometime this summer I took the entire headliner off and sealed the leaky roof that these DII's had but didn't bother to work on the back sunroof at the time. What do you suggest might be the issue?
Thanks so much and hope everyone is enjoying the holiday season!
Old Dec 29, 2017 | 10:44 AM
alpinacsi's Avatar
Can you hear it attempt to move. have you tried swapping the switches with the other roof. Are you trying the switch at the front. What have you tried at this point? There are so many things that it could be but first is to check for power.
Old Dec 29, 2017 | 10:59 AM
dasherman's Avatar
I can't hear it attempt to move at all, I press the switch and there's nada. I suppose I could swap switches to see if power even runs to the back. If it does, it might be a motor?
Old Dec 29, 2017 | 11:37 AM
shanechevelle's Avatar
Drop the headliner a little bit and take that motor out. Its probably shot from water or age.
Put a multimeter on the harness and have someone press the switch. You should have a reading.
Old Dec 29, 2017 | 06:09 PM
Extinct's Avatar
There is a little square plug that can be popped out of the plastic trim just a few inches from the switch. Once it is popped out you can put a small allen wrench in the motor shaft (forgot the size), can turn the motor by hand. If it doesn't turn, the problem is the motor. Pop the switch out and there is a screw under it, pull the trim around the sunroof and you can drop the headliner enough to remove the motor.
If it does turn, could be switch, relay, or control module.
Good luck.
Craig Carloss
LR2
Oct 19, 2017 09:31 PM
akilbrid
Aug 20, 2017 12:18 AM
BigRed98
Jun 21, 2010 12:30 AM
kayaku
Nov 20, 2008 08:33 PM
dmm698
Aug 28, 2007 06:37 AM
