battery dead, key hole broken
Old Nov 7, 2009 | 08:34 AM
Baylink's Avatar
The starter cable. Sumbitch; I didn't even think of that. And it won't take long; just hooking it up will probably provide enough current to run the BCU and solenoids.
Old Nov 7, 2009 | 08:56 AM
Originally Posted by Arizona man
I need to get my hood open from the outside so i can charge the battery. How would I do this?
Send me your number and I'll walk you thru how to get in.
Old Dec 30, 2009 | 06:59 AM
Arizona man's Avatar
Ok. So after trying to jump the battery from the starter cable and not succeeding I pulled out the driver side headlight and stripped the hood release cable down through the rubber and snipped the metal surrounding the cable enough to pull on it and I got the hood to pop. But now after charging my battery I have this wild clicking noise while starting and a buzzing noise from the dash but the engine does not even attempt to turn over. Any ideas?
Old Dec 30, 2009 | 07:03 AM
Baylink's Avatar
I'd get a voltmeter on that battery; "wild clicking noise" while trying to crank is -- generally -- that your battery voltage is too low, and as soon as the solenoid pulls in to try to crank, the voltage drops far enough that the solenoid drops out again; lather, rinse, repeat.
I think the minimum crank voltage is supposed to be something like 9.6vdc.
Even freshly "charged", you battery may have had a cell short out or otherwise go dead.
Old Dec 31, 2009 | 12:46 PM
It was the battery, thanks.
DISCOENO
May 2, 2014 12:45 AM
ljdiscovery
Feb 10, 2014 08:58 PM
sfxgamer
Dec 24, 2010 12:58 PM
audiS4S6
May 6, 2010 12:14 PM
