Battery relocation
Looking underhood,noticed if battery and jack stowage was relocated to back, there would be a decent spot open to place a fan-equipped engine oil cooler and the battery would be away from the hostile underhood heat to live a longer life
My Porsche 928 has rear batt and I converted my Z28 to rear-typically get 10-12yrs of battery life with those.
Seems like a lot of effort, for little gain. Also, if you ever decide to install a front winch...you'll be running extra cables back again. Plus, you'd have to create a "jump post" like the 928 has...or you'll be digging for the battery compartment, whenever you run it dead. And, l believe there is less bouncing around up front. You steer to avoid a pothole/bump with your front tires...only to be hit with your rears.
Just some thoughts on the idea.
Brian.
Brian.
-to provide a nice oil cooler location-if I decide to add one,that will depend on what oil temps I find the engine runs once the engine repair is completed(head gaskets,valvetrain,ETC- the late disco usuall
)-if it gets over 250 often under adverse conditions,will install the cooler to keep the oil ~230* do not want to over cool the oil either or the additives may not work as well-important with our flat tappet cams-not to mention evaporating off any moisture in the oil.Added cooler to my Z28 after I discovered oil was getting up around 290 under certain conditions..If a winch was installed-don't plan to-the voltage drop of the cables to the rear would need to be considered...In my Z28,the rear batt is very handy to get to,but in the 928,sits in a little hatched well under the spare tire under the rear carpet
If I decide to relocate the batt in the disco,one of the rear storage compartments will be investigated to see how much space is avalible behind the inner wall...
I dont think the oil in a rover gets anywhere near that.
Many of us have over 200,000mi with no issues with oil.
the issue with the oil pump is a design flaw that has nothing to do with temp.
even our transmissions are usually trouble free.
idk why you would waste the time for such a small benefit.
I'll se what oil temps run once back in operation.I did notice reports of transmission problems are pretty rare-yay
Another location for oil cooler I have considered if I decide to add one is on the back side of the radiator-will have heated air going through it,but oil will be much hotter and still cool well-thermostat added plumbing to prevent ovecooling .No wiring,fan or battery relocation needed-real easy
The other method with fan would be pretty easy too.-that is the setup installed in the z28-control the fan to regulate temp,works great.
