Best Code Reader to Buy for 2000 Disco 2
Old Sep 17, 2018 | 10:07 AM
Motorhead1's Avatar
I purchased one of these Autel AL619 a few years ago after doing extensive research on this forum and others, it does everything except reprogram a LR and bleed the ABS pump. It's been great. After you purchase it, you then download all the info onto the unit, takes about an hour to get it done. It's been great.
Amazon Amazon
Old Sep 17, 2018 | 04:46 PM
330deadpool's Avatar
my mechanic said i have 28 codes pop up on his code reader and that its amazing the truck is still running smooth, so maybe i won't get a reader on the basis of out of sight out of mind
Old Sep 17, 2018 | 09:46 PM
Wesley Lueders's Avatar
I've got an iLand scanner tool. I was unable to load it on my iphone, but was able to on an old android phone. It does quite a bit and will program remotes for the D2. I've used it so far for ABS bleeds, trouble shooting the cruise control system, and shut off the SLS after the rear spring conversion. The only downside is there's no user manual, with all the different menu items, it can take some time to get where you want to work on.
Old Sep 19, 2018 | 12:15 PM
climber404's Avatar
Does anyone know if the NT520 will pull the correct codes for the three amigos?
Thanks.
David
Old Sep 19, 2018 | 08:55 PM
Yes, it will. I had a 520 pro for a short time, but returned it due to what I think were software glitches. The seller preferred to give a refund vs. trying to fix the issues. I had to pay the return shipping. Caveat emptor.
Old Feb 21, 2019 | 06:26 PM
DiscoSage's Avatar
4th Gear
FoxWell NT 630 Elite $119
Power-bleed
Modular Bleed
SRS
Air to Spring Conversion
Cheers Craig
Old Apr 29, 2025 | 11:13 AM
CharminULTRA's Avatar
Power-bleed
Modular Bleed
SRS
Cheers Craig
Instead of creating a new thread, I'm here to report that the Foxwell NT 630 successfully CLEARS ABS CODES. I was able to resolve my 3 Amigos by using this scanner to diagnose the issues, perform wiring fixes and Option B bypass, and finally clear them in the system with the 630.
Old Apr 29, 2025 | 06:57 PM
Frank4's Avatar
I’ve had this for years. All you need and I didn’t have to program mine.
Old Apr 29, 2025 | 07:06 PM
disco96sd's Avatar
nanocom $590
Old Apr 29, 2025 | 08:07 PM
Extinct's Avatar
I upgraded to the foxwell NT680 because it reads all the modules on my 08 Avalanche too.
Seattled2
Jun 23, 2020 09:06 PM
Sixseven729
Feb 17, 2019 03:20 AM
ReconDoc83
Sep 17, 2018 01:24 PM
GGhost
Dec 31, 2013 03:55 PM
