Blowing Fuse
Old Apr 2, 2012 | 08:37 AM
johndreaney's Avatar
Default Blowing Fuse
Hello all. I am having trouble with blowing a fuse. The truck keeps blowing the cigarette lighter fuse. I don't smoke but I use that receptacle for my GPS. Originally I think it was a 15A, at one point I put a 30A in there and it blew that as well. Is this common? Is there something I can look at to see what is causing this?
Old Apr 2, 2012 | 11:22 AM
1. The solutuion is not to put in a larger fuse to supply more energy. Like searching for a burning smell by spraying gasoline.
2. That fuse would be FUSE 15 inside the truck. It is speced for 20 amp. If a 20 blows, there is more on that circuit than just the lighter. Like seat heaters and vanity mirror light which show up on the RAVE wiring diagrams.
Old Apr 2, 2012 | 11:33 AM
Default Fuses
I thought the seat heater fuses were under the seats and I thought they were bigger than 20A. Didn't realize there was something else on Fuse 15 other than the cig lighter.
Old Apr 2, 2012 | 12:03 PM
I figure that the dealer would be glad to change them all for you. See attached, pix of seat fuses (they handle the motors), page from owner's manual (which shows I missed a light somewhere), and schematics of the the cigar lighter, seat heater circuit, and vanity mirrors. The RAVE makes you look in multiple places for the same thing. (RAVE = Rovers Aren't Very Easy)
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Apr 2, 2012 | 01:06 PM
Default Interesting
Only had the truck about a month and the drivers seat will not heat. Wonder if there is a short there that might be causing me to keep blowing the fuse?
Old Apr 2, 2012 | 02:45 PM
A distinct possibility. If you download the RAVE set of manuals, there is a circuits manual that will show a color coded wiring plan, and an electrical library that hase a picture of about every connector, so you can see where they are, etc.
Old Apr 2, 2012 | 05:42 PM
abrady's Avatar
My driver seat blows the fuse when I try to recline it. I solved it by no longer reclining. I've been to busy to chase that rabbit. However I have thought about rewiring it so it is a constant on and Idont have to have the truck on to run accessories.
Old Apr 2, 2012 | 06:47 PM
collin Barrows's Avatar
My 95 disco does the same thing. I also don't smoke and only use it for my gps. since my rover doesn't have heated seats, I've gone threw 3 20 amp fuses and now I've just kinda given up.
Old Apr 2, 2012 | 07:21 PM
Well, the rest of the fuses are content to hang onto life and not go out in a ball of fire. So perhaps one path would be to remove the problem area fuse, connect an amp meter in place of it, so you can see exactly how many amps are passing that way. Let's say you get 12 amps. And cigar lighter is not plugged in. Start disconnecting things to find what is making the draw. Get out you test light. Now D1 and D2 have different wiring harness, so be sure to look it up in your own personal copy of the RAVE that you have studied until the screen grows dim on the laptop.
"I keep putting in a fuse and it keeps blowing." Yep, it is blowing a whistle trying to get your attention.
Old Apr 10, 2014 | 11:18 PM
jccrew1982's Avatar
Agreed: I try not to bring old threads up from the dead, but I thought I would just mention that a quick check on a D2 with symptoms of a blown #15 (cigar lighter/vanity mirror light/heated seats) would be to just take a multi-meter with the ignition off and run a continuity test between those devices. I just had this problem and found my short to be above the passenger vanity mirror. I unscrewed the three screws holding the visor and wires in place to find that the wire was torn up by the last person to screw in the visor (probably me). All switches and devices work again now
Jameslandrover110
Defender
Feb 18, 2011 02:46 PM
GoldDiscoII
Jan 31, 2009 09:09 PM
mark 07
Dec 24, 2007 03:34 PM
jmt
Dec 23, 2007 06:16 PM
MalcySP
Jul 12, 2006 05:45 PM
