broken rocker arm?
Old Oct 24, 2012 | 09:45 AM
jfall's Avatar
Crap man.
There is no lubrication up thru that oil hole to the rocker shaft.
The whole shaft has to be aligned with the oil hole.
How to fix????
I would take the rocker arm OFF -
and CRANK the engine.
See if any oil is coming OUT of the holes to the rocker arm.
Probably ONE passage is clogged.
Sorry man.
This is bad news for all of us.
Must must change OIL every 3,000 or less.
I dislike voodoo products like Seafoam but this seems a case for it.
Old Oct 28, 2012 | 04:45 PM
DylSmi's Avatar
4th Gear
The shafts being worn may well have lowered oil pressure, so other engine parts are likely worn heavily as well, like main bearings. You are seeing just part of the problem. Thicker oil won't help at this point. You could also have a slipped sleeve thrown into the mix that is also ticking.
These can all be fixed, and there are posts and write ups on this site to guide you. along with the shop manuals. But you need tools, and a place to work, leave engine torn apart, etc. And $1000 is a very common figure to burn thru on a new-to-me Rover with minimal problems.
For a college car, find a cheap common import or a basic Ford or Chevy with the paint peeling off of it, you can get parts cheap at the junkyard. I have a D1 for my kid who is in college, spent a lot of hours and real dollars on getting it roadworthy. Now she puts maybe 40 miles a week on it because of the on-campus bus system.
Anyone can learn to work on a Rover; and you can buy tools, but finding a place to work on it can be a challenge. And the time spent away from your studies is a big negative. I doubt that you are taking only one class per semester.
Okay thank you both. I'm going to be driving two plus hours a day for college then back. And I like how styles the land rovers are and how roomie they are.
rlrigsby
Nov 27, 2018 05:09 AM
SUMOSINO
Dec 10, 2014 09:02 AM
acamato
Jul 27, 2013 02:10 PM
vrblknch
Apr 12, 2011 09:14 PM
mburnett
Mar 27, 2008 09:07 PM
