Broken/stuck piston oil ring...
Old Jan 31, 2016 | 03:47 PM
slammin_LWB's Avatar
Default Broken/stuck piston oil ring...
2001 D2, 4.0.
I've fixed every oil leak on the thing and was using 2qt/60 miles or so. Also was getting misfires on cyl7....plug fouling. Oil. No real smoking unless I really stomped it. Head gaskets done about 20k miles ago.
Anywho....cylinder 7 has a bad ring. Now...it still has great compression. Around 160psi, as do the other 7 cylinders. I'm thinking I can pop the head off, drop the pan, and slip #7 out, re-ring it, and slip it back in. I'd probably do all the rod bearings while it was apart too.
Thoughts?
Dropped a bore-scope into the cylinder for confirmation.
Old Jan 31, 2016 | 08:02 PM
The_OGCJR's Avatar
Side note, I've never seen a stuck ring cause low compression. I suppose it could happen.
2 qts every 60 miles is crazy! Your plan sounds good to me though. I can tell by your car list, and your strap-on er...snap-on tool you kinda know what your doing at least!
Old Jan 31, 2016 | 10:11 PM
Haha, I try. I know those BMWs in and out. The Rover is, kinda, a different animal....although I learned by doing on all those cars in my sig.
Also I work at an indie Euro shop specializing in German cars.....hence the Snap On goodies. Shop tools, lol.
Hopefully this week I can get this thing torn down for exploratory reasons. Planning for the worst. ....mostly because I wanna work on the SIII 109 I got a few months ago.
Old Feb 1, 2016 | 06:35 AM
drowssap's Avatar
have you checked the valve guide seals on number 7?
Old Feb 1, 2016 | 09:05 AM
They were replaced when the headgaskets were done 20k ago.
Of course nothing is ruled out until I get into it....
ImQuattro
May 1, 2014 08:36 PM
Scott Crutcher
Dec 6, 2012 01:34 PM
honda50r
Oct 30, 2012 07:47 PM
cterrebonne
Engine & Internal
Oct 14, 2006 07:47 PM
sanchez
Aug 3, 2006 10:24 PM
