A/C Condenser fan
Old Aug 13, 2012 | 01:13 PM
matt3502's Avatar
Found a used one out of an '03 for $55. If it fails then I will go thru pulling old one apart and replacing with AC Dleco fan. Thansk for all the advice fellow Rovers
Old Aug 24, 2012 | 05:44 PM
ebg18t's Avatar
Originally Posted by jomandm
Yes do a search through some of the old posts. There was a write up on which motor models are compatible with our trucks. I just replaced my condensor fan this weekend and the AC Delco 1580341 was the recommended motor. I got it through amazon for $74 new.
Amazon.com: ACDelco 15-80341 Professional Fan Motor: Automotive
Did the fan come apart easily to replace the motor?
Old Aug 27, 2012 | 11:24 AM
jomandm's Avatar
The mounting bolts were rusted and had to soaked in pb blaster for an hour or so. I had to drill one of them out to remove the fan. I bought new bolts at ACE. I didn't have to modify the fan shroud to install the new ac delco motor which was good.
Old Aug 27, 2012 | 03:48 PM
ebg18t's Avatar
does that ac delco flow more air than the stock one?
Old Aug 27, 2012 | 04:30 PM
No, it is a close match in fractional hp and rpm.
Old Aug 27, 2012 | 04:33 PM
ebg18t's Avatar
is there another part # that does run at a higher flow?
aemnky606
Jul 6, 2024 10:53 PM
EstorilM
Oct 8, 2019 08:26 AM
RegT
Jun 23, 2010 08:32 PM
discomedic4
Jun 12, 2010 06:46 PM
jmt
Jan 14, 2008 05:01 PM
