Can I install an '04 SLABS unit to my '02 without CDL?
#21
Good it's not the BCU though, now that would be fun eh
#22
Spoke too soon. Since I noticed I had the same SLABS after installing the new one, I decided to just leave it there. Now I have 4 amigos, abs error code 4022 - earth ground issue. Reverted back to my old one, works fine.
Fun little exercise removing and reinstalling the glove box twice...
#23
Not true in all cases. For what Jeff wants, setting to coil is all that's needed.
If setting to air and it has never been set to air before, the ride height needs to be calibrated. Otherwise you end up with HDC and spring errors on the dashboard and you can't change the ride height.
#24
Interesting specificity. From what I could tell from a read-only POV (using a borrowed Hawkeye), calibration involves raising or lowering each side until a designated ride height is reached, and then setting that position as the baseline for that air spring.
However, that does not apply in Jeff's case since he's going the other direction. I assume that switching to coils makes the height settings irrelevant.
#25
I have never calibrated a D2, but have done many LR3s, Im guessing the principal is the same. The tool being used cycles through the height settings then asks for you to take measurements and input into the tool. Then it makes adjustments and asks for a second set of measurements. Once those are confirmed and no faults it's done.
Jeff Blake
09-01-2017 12:16 PM
jamieb
04-02-2016 10:33 AM
ls1morethanyou
07-28-2014 11:06 AM
lipadj46
02-11-2010 07:45 AM
