CD Cartrigde Stuck in Player
Old Apr 2, 2017 | 03:57 PM
LMcInnis's Avatar
Default CD Cartrigde Stuck in Player
2000 LR Disco. Getting a CD-Error message on the radio screen, then after attempting to eject the cartridge (under the seat) I get a "no magazine" message.
Any ideas on how to remove it? Thinking one of the CDs is out, stuck inside the player (hence preventing ejection).
Appreciate any ideas; thank you,
Larry
Old Apr 2, 2017 | 04:00 PM
Best4x4's Avatar
Can you push it back in? If not there is most likely a CD stuck in the middle or a stuck tray in the magazine. If pushing it in doesn't fix it your best bet is to remove it from under the seat, and take the cover off to visually inspect it.
Old Apr 2, 2017 | 08:51 PM
Rosslato's Avatar
Yea i've got the exact same problem. Do you take it out from the back of the seat?
Old Apr 2, 2017 | 11:35 PM
Best4x4's Avatar
In order to get it out easily remove the lower trim under the seat. Then disconnect it from the rear and just slide it out the front. Bracket is held into place with 4 10mm nuts.
Old Apr 3, 2017 | 06:59 AM
matt3502's Avatar
I had the same problem a while back. I found that by pushing on the CD magazine and pressing the eject button at the same time it would pick up the stuck CD and then eject the whole magazine. When mine died, all I was take out the four nuts holding it down with a ratchet. I did not remove any trim, and came at from the back side.
HawesEA2
Dec 17, 2016 09:47 AM
ImQuattro
May 1, 2014 08:36 PM
Scope
May 2, 2013 03:54 PM
smyevich
Aug 31, 2006 01:31 PM
