Check please!
Old Jul 26, 2016 | 10:05 AM
jamestfl's Avatar
Default Check please!
Check my thinking / planning on this. So I've got an oil leak that appears to be coming from the Crankshaft seal or front cover seal. Am planning on getting in there to repair/replace. Also have oil leak from valve cover gaskets. Here's the list of to do's while I'm in there:
Crankshaft seal
Timing chain and gears
Oil pump and gears
Valve cover gaskets
Front cover gasket
Oil pressure switch
Inline thermostat mod
Plan to purchase AB kits where applicable.
Edit- also getting oil light at idle, sometimes. Never had this before.
Any other suggestions? Preciate it...
Old Jul 26, 2016 | 10:45 AM
drowssap's Avatar
If it were me I would replace the front seal which can be done in the truck and see if that solves your problem.
Replacing the oil pump and timing chain is a great idea, both require dropping the oil pan.
Crankshaft seal
Oil pump and gears
Valve cover gaskets
Front cover gasket
Oil pressure switch
FlyingZebra34
Feb 22, 2014 05:39 PM
Jst4fun
Nov 3, 2013 05:19 AM
bosshogt
Sep 24, 2011 11:07 PM
tads
Aug 2, 2007 12:09 PM
Brad S1
Jul 15, 2006 03:16 AM
