Check please!
Check my thinking / planning on this. So I've got an oil leak that appears to be coming from the Crankshaft seal or front cover seal. Am planning on getting in there to repair/replace. Also have oil leak from valve cover gaskets. Here's the list of to do's while I'm in there:
Crankshaft seal
Timing chain and gears
Oil pump and gears
Valve cover gaskets
Front cover gasket
Oil pressure switch
Inline thermostat mod
Plan to purchase AB kits where applicable.
Edit- also getting oil light at idle, sometimes. Never had this before.
Any other suggestions? Preciate it...
Crankshaft seal
Oil pump and gears
Valve cover gaskets
Front cover gasket
Oil pressure switch
If it were me I would replace the front seal which can be done in the truck and see if that solves your problem.
Replacing the oil pump and timing chain is a great idea, both require dropping the oil pan.
Crankshaft seal
Oil pump and gears
Valve cover gaskets
Front cover gasket
Oil pressure switch
Crankshaft seal
Oil pump and gears
Valve cover gaskets
Front cover gasket
Oil pressure switch
