clunk when shifting
clunk when shifting
Hi I have a 1999 Disco 1 with 135,000 miles on it. The tranny makes a clunk sound when shifting into reverse from drive. This is only when the truck is warmed up too. No sounds in the morning or after its been sitting for a few hours. Is this a u-joint problem or will I need to change the front drive shaft? Rather have it done sooner than losing my tranny. Thanks for any advice.
Sounds like a u-joint going out. Mine started that way when the u-joint at the rear diff started to die and continued to get more common as it got worse. It went from only making the clunk when I shifted into gear to clunking every time I accelerated. U-joints are pretty cheap and easy to replace and if you haven't been keeping them greased they probably need replaced.
on
A quart low will kill you t/case, you need to start taking batter care of your truck. I would highly suggest if the rest of your truck has been this neglected that you go thru and change all your fluids.
As for the u-joints, they have to be greased at least 2 times a year or they will fail, so have them inspected and greased or replaced ASAP.
