clunk when shifting
Old May 7, 2010 | 02:01 PM
discoken's Avatar
Default clunk when shifting
Hi I have a 1999 Disco 1 with 135,000 miles on it. The tranny makes a clunk sound when shifting into reverse from drive. This is only when the truck is warmed up too. No sounds in the morning or after its been sitting for a few hours. Is this a u-joint problem or will I need to change the front drive shaft? Rather have it done sooner than losing my tranny. Thanks for any advice.
Old May 7, 2010 | 03:20 PM
How often do you lube both drive shafts, when did you last check your ATF level, is it burned, when was it last changed?
Old May 8, 2010 | 10:40 AM
discoken's Avatar
ATF was just changed last summer. I'm going to have the shafts looked at.
Old May 8, 2010 | 11:34 AM
Long Haul's Avatar
Check your transfer case fluid. Mine was the same way untill I changed the fluid and it made it a lot quieter afterword. Your D1 doesnt have the double cardan joint that the DII's have. Might want to replaice the diff oil also
Old May 8, 2010 | 03:25 PM
AK Rover's Avatar
Sounds like a u-joint going out. Mine started that way when the u-joint at the rear diff started to die and continued to get more common as it got worse. It went from only making the clunk when I shifted into gear to clunking every time I accelerated. U-joints are pretty cheap and easy to replace and if you haven't been keeping them greased they probably need replaced.
Old May 9, 2010 | 10:47 PM
discoken's Avatar
The u-joints were good, the transfer case was about a quart low so refilling it has quieted the clunking down. Looks like I'm going to need to replace the transfer case in the near future.
Old May 10, 2010 | 08:37 AM
A quart low will kill you t/case, you need to start taking batter care of your truck. I would highly suggest if the rest of your truck has been this neglected that you go thru and change all your fluids.
As for the u-joints, they have to be greased at least 2 times a year or they will fail, so have them inspected and greased or replaced ASAP.
scootch61
Nov 30, 2013 02:49 PM
CUpgt
Jul 1, 2011 12:30 AM
DiscoMike2003
Nov 13, 2008 04:57 PM
GeorgeD
May 19, 2008 07:31 AM
bmartin2
Feb 18, 2006 02:49 AM
