Clunking windshield wipers
Old Feb 19, 2010 | 02:40 PM
salve7's Avatar
Default Clunking windshield wipers
I am having an issue with my wipers lately and I can't find anything by searching the forum that helps. They are clunking, hesitating, and making a lound clunk when I turn them on. I have seen that there is a wiper moter and transmission so I am assuming it is the transmission as the wipers still work. Is there an easy way to tell and what simple things should I start with first? Could this just be a loose nut (on the wipers, not me)?
Old Feb 19, 2010 | 03:27 PM
hilltoppersx's Avatar
are they both in hesitation together or just random?
Old Feb 19, 2010 | 04:01 PM
salve7's Avatar
Both together. They will travel a little distance, clunk/ hesitate and continue.
Old Feb 19, 2010 | 05:05 PM
tbesselman's Avatar
I had the same problem (99 DII) and they also wouldn't always go back the park position. Had to replace the wiper assembly, I believe you can buy just the motor too, I just bought the whole assemply......pretty easy DIY....good luck (get the rave manual to show you how to do it)
Old Feb 19, 2010 | 07:00 PM
greg409's Avatar
I'd guess the crankarm off the motor/trans ***'y is coming loose.
Do they still park correctly? if not, my bet's the crankarm.
luck,greg
Old Feb 19, 2010 | 07:07 PM
salve7's Avatar
Yeah they park fine but I am willing to bet it will get worse. Is the crankarm something you can get individually or should I just get the whole assembly and be done with it?
Old Feb 19, 2010 | 07:27 PM
greg409's Avatar
This is like IM
I'm too lazy to look in rave, but Something tells me that it's accessable thru access panel in cowl
luck,greg
Old Feb 19, 2010 | 08:02 PM
salve7's Avatar
Yeah I've been to lazy to look at the rave myself but I guess that will be my next step.
Old Feb 20, 2010 | 09:31 AM
Rovin4life's Avatar
loosen up the hood and slide the cowl off of there. lot easier then side posts
greenfish
Oct 3, 2018 02:36 PM
yevgenb
LR2
May 4, 2009 12:21 AM
JBEGIN
Dec 23, 2008 02:08 PM
DiscoGravy
Jun 26, 2006 03:26 PM
brianwi11iams
Jul 20, 2005 02:36 PM
