Coil packs -- which to buy
Plug wires are new.. it has over 100k, but seems to run clean and oil is never cruddy after miles on it... We change at 2,500-3,000k miles.
Has new front end work and transfer case?..previous owner had some service, but drove it. Thank you for your help and advice.
I'm posting here so maybe someone can help out. Does anyone know the specs on the bolts that hold the coil bracket onto the IM? I checked the RAVE and all it gave was torque settings. I'm replacing my ignition leads and discovered that whoever was poking around there last didn't properly secure the top 2 bolts on the flanged side of the bracket. I'm guessing they either dropped them or were just lazy, but in any case I don't want my coil packs bouncing around!
I think they were short 8mm bolts... worth double checking.
They are M8 but I can't remember the pitch. Very fine thread. Top is about an inch long and bottom is a little shorter.
meltdowndave
Dec 29, 2009 01:54 PM
