Coil under the coil packs?
Old 11-10-2014, 04:00 PM
acamato's Avatar
Originally Posted by trialrun
got the waterfall sound taken care off, no more meditating in the rover for me.
As for the blower motor, where would the leaves come in at?? I can't for the life of me find any openings on the firewall to dig them out
The leaves enter from the opening under the cowl. To remove them, you need to drop the blower.
  #82
Old 11-11-2014, 06:31 AM
drowssap's Avatar
there isa filter at the base of your windshield which is probably deteriorated
  #83
Old 11-11-2014, 08:41 AM
trialrun's Avatar
So I'm not sure where amazon copied those reviews from, but the MAF is definitely not a direct fit into the 03-04 4.6 discos. It's about a 1/4" smaller in diameter. Another thing to note is the Bosch security screws are a 5 point t20 vs the aftermarket 6 point t20. Couldn't find a 5 point t20 in my tool box but a vise and some pliers will take it right out. All the part numbers were the same, just the housing was off so I simply swapped the Mass airflow sensor itself, running right so far
All done, I used the new screws so I won't have any issues with removal next time around
jdhuegel1
08-01-2011 07:22 AM
moomoo
05-23-2011 01:16 AM
elboy0712
03-11-2010 10:18 PM
meltdowndave
12-29-2009 01:54 PM
03discoman
04-27-2009 09:54 AM
Quick Reply: Coil under the coil packs?
