Coolant hose too close to tensioner?
I'm replacing my lower radiator hose set, and after getting it all in place, the pump to thermostat hose is only about a half an inch from the tensioner with tension on the belt. Has anyone else had this occur? I don't feel comfortable with it being that close. I can wiggle it and get it to touch the pulley.
The tensioner is aftermarket. The lower hose set is URO brand. It all looks right to me, so I'm wondering if the 3 way plastic piece is the wrong angle or something. I don't know.
I guess for now I'm going to find a semi-permanent way to hold the hose back, but I'm not happy about it.
picture forthcoming
picture forthcoming
It's a poor design for sure. To make things worse the serp belt will sling whatever happens to be in the engine bay right onto that hose which can make it gummy/weak in that one exposed spot over a relatively short amount of time.
I'm not a huge fan of the popular alternative cooling hose routing and low-temp thermostat option, but it does mitigate this particular issue.
Brandon318
08-29-2019 10:57 PM
EstorilM
12-14-2010 08:33 AM
