Coolant leak from back of engine
Old Jul 13, 2015 | 09:45 PM
Two Rock's Avatar
It's probably the head gasket at that mileage you are due anyway
Old Jul 14, 2015 | 11:42 AM
If you are going to pull the heads, make check for wear on the rocker shafts, rockers, lifters and cam lobes because at your mileage you may be showing some wear.
Old Jul 14, 2015 | 11:58 AM
texdisco's Avatar
6th Gear
Thanks Mike . . . Found a place that will take engine out, machine head, replace head gasket, oil pan gasket, rear main seal, replace electrical, etc . . . . for 3,200 . . .
Will have them inspect rocker, lifter, etc then . . .
Old Jul 14, 2015 | 12:24 PM
Now you know where not to take it, talk about charging.
A good Rover mechanic will do the head gaskets, heads and inspection for around $1800 or so.
We should talk before you make a move.
Old Nov 2, 2015 | 07:58 PM
chubbs878's Avatar
So what happened?
ZMonet
Jun 24, 2016 04:00 PM
BrandonG83
Nov 3, 2015 09:11 PM
Rufflyer
Mar 22, 2015 10:13 AM
coloboy
Feb 9, 2014 01:38 PM
sadain
May 3, 2012 09:40 PM
