coolant in sump
Old May 7, 2018 | 05:52 PM
Tomzsix's Avatar
Default coolant in sump
I know my motor is toast since last November. Haven't checked dipstick until today. Coolant has migrated into sump without engine running. How could this happen?? Still saving for a "Turner engine".
Old May 7, 2018 | 06:54 PM
Sixpack577's Avatar
Head gasket or cracked head or block allowed coolant into cylinders.
Truck sat, coolant seaped past the rings, and/or out of a crack in a cylinder wall, drained right down into the oil pan.
Old May 8, 2018 | 08:49 AM
robert.juric's Avatar
How do you know the motor is toast? How do you know it's not just the HGs?
Old May 8, 2018 | 07:56 PM
Tomzsix's Avatar
No coolant from exhaust. Always disappeared somewhere, until I checked dip stick. then I realized the disaster. Coolant into sump. Cracked block.
Old May 8, 2018 | 08:06 PM
Can’t coolant leak into a cylinder from the HG and then past the rings into the sump?
Im just saying it may be worth checking out before you buy a whole new engine. HG job is much cheaper than an engine swap. Unless you want the engine for peace of mind, then right on!
Old May 9, 2018 | 08:33 PM
Jwehking's Avatar
Front cover or intake coolant leak?
Old May 10, 2018 | 01:40 PM
nickm347's Avatar
Remove the oil filter and the coolant hose that goes into the lower intake.
Pour water into the hose/intake and if it pours out where the oil filter goes, then its a front cover gasket.
Old May 10, 2018 | 04:11 PM
shanechevelle's Avatar
Some people prefer a raped pocketbook then a correct diagnosis
Old May 11, 2018 | 07:53 PM
Tomzsix's Avatar
Before I parked it, pressure build up in reservoir would leak out coolant. Yes, new cap. Then after a week, coolant would disappear into sump, causing motor to get a little warm. If that sounds like front gasket, then I will do this test this weekend.
Thanks guys for the help.
tito5590805
Apr 28, 2020 12:53 AM
OffroadFrance
Mar 31, 2014 05:10 PM
larfburger
Oct 25, 2012 09:11 AM
Fireman
Nov 23, 2010 10:08 AM
griffker
Mar 16, 2009 07:19 PM
