Coolant system redo/upgrade options?
Old Jun 24, 2016 | 05:42 PM
  #21
Alex_M's Avatar
Awesome, glad you found it. There's only 1 size in the housing.
Hose diameter is 1.5"
As for the fan, I'm not sure on the Dorman number. I ordered a used ford fan out of a wrecked mustang I believe, but its the same as the Taurus fan.
Old Jun 29, 2016 | 08:13 AM
  #22
CollieRover's Avatar
hey Rawfaith, Any updates on how the fan install went?
Old Jun 30, 2016 | 12:51 AM
  #23
chubbs878's Avatar
It's 1.25 on the top hose. The 1.5 inch housing is probably what he ordered and that is going to be the incorrect size. The bottom radiator outlet uses a 1.5 ID but the upper hoses are 1.25
Old Jun 30, 2016 | 01:03 AM
  #24
chubbs878's Avatar
Originally Posted by disc oh no
That's still not too bad. Does this modification go up near the top of the engine bay where you can get to it easy? If so, that alone would make it worth doing.
On the upper hose you want the thermostat in place closest to the engine amnd your sender/purging valve after. Replace the smaller plastic coolant lines with new OEM or new hot water tubing. The tubing that I bought from the parts store was oil-cooler grade and also has a thick wall to it. If you aren't going to replace the throttle body gasket kit then bypass it altogether if you haven't done so already. On mine, the hoses def needed replacing where it exits the intAke manifold. For the upper hose mod, you may want to make use of the type in this attached photo. I'm going to get one of these for appearances and functionality. I don't like the reuse of the factory hoses pieced back togetheR.
Attached Thumbnails Coolant system redo/upgrade options?-image.jpg
Old Jun 30, 2016 | 08:10 AM
  #25
Alex_M's Avatar
My mistake, though there is only one housing size to my knowledge. The one I had was the correct size (1.25") on one side and large (1.5" or perhaps 1.75") on the other size. It fit using a cut piece of one of the lower hoses and some stretching. The lower hose that he needed to order is still 1.5", so that's correct.
Old Jun 30, 2016 | 09:45 AM
  #26
chubbs878's Avatar
nope. the Mezeire is 1.25 in, 1.25 out; I used the factory upper hose split in 2 pieces to connect it up. they have a different part number that is 1.5 in and 1.5 out as well.
I'm not trying to call you out on this, only trying to save someone from doing a run-around.
Old Jun 30, 2016 | 12:46 PM
  #27
Alex_M's Avatar
Oh! Well my mistake. I do appreciate the correction, I wouldn't want anyone buying the wrong part either, especially because of my ignorance on the matter.
hankeester
Jan 9, 2015 12:58 PM
Street Wolf
Dec 23, 2014 05:35 PM
2Discos
Jan 25, 2014 06:45 PM
LeakyDisco
Off Topic
Dec 12, 2011 06:59 PM
slanginsanjuan
Nov 18, 2011 06:33 AM
