Crankshaft Pulley Bolt 15/16 or metric? Removal and refit methods?
Thanks everyone - I’m trying to weigh the options.
If I use an impact wrench, will I need a special harmonic balancer impact socket rather than a regular impact socket? That would cost $100 instead of about $17, if the wrench fits between the radiator and the bolt - at least for a 15/16 socket. The 24mm is less, but is that risking damage to the bolt by using the wrong size?
I’m just thinking that using the wood block method with a breaker bar (I have a 3’ x 3/4-drive bar) will still be very difficult to remove this bolt, but maybe it’s not so bad? The socket would cost $13. I can start spraying it with penetrating oil now.
Also, how would I know if the three studs on the bottom of the front cover were replaced with bolts, so I could remove the front cover without dropping the oil pan? I’ll still have to remove the crankshaft pulley, but this could make the rest easier.
Since the front cover is cracked, I’m afraid to tap the starter to loosen the pulley bolt.
Thanks again
Thanks again
I did mine with a large 1/2" rachet (like a 2ft snapon with articulating head) and a large strap wrench. I got in there with a 24mm socket and it wasn't a problem for me. For install, I just did the reverse and then torqued to spec while counterholding with the strap wrench. Only caveat to my method is I do my work on a lift where I'm standing which may change how you'd approach the problem. If you pop the fan off, you can get a right angle impact in there as well if you're so inclined.
Hi, well its only 200 lbs at 1ft or 100ft at 2 foot snap on bar thats not a lot so I think your over thinking this, but if you need a bit of extra help, watch this video it will give you a bit more confidence
https://www.youtube.com/watch?v=_h0TpEZJ-68&t=93s
just make sure the strap is round the correct way to hold it tight when you go to loosen it so it needs to wind round anti clockwise
I own a Tacoma that I have to do the front crank seal on as well.
