creaking crunching sound while steering
Old Aug 4, 2008 | 03:51 PM
Default RE: creaking crunching sound while steering
If you put in to much when it gets hot and expands and builds pressure you can blow your axle seal and then your gear lube will get into your ***** and you will leak and have a mess.
Old Aug 4, 2008 | 03:52 PM
Remove the fill plug on top, 20 pumps with your hand held maunal type grease gun and call it good. Simple as that. Really. That simple.
Old Aug 4, 2008 | 06:52 PM
TheBelly's Avatar
so, if there is already a bunch of nasty goo on the outside of my swivel ***** right now, there might be a problem?
Old Aug 4, 2008 | 07:17 PM
No. Just clean them up really good, use carb cleaner or a good degreaser, like Simple Green or Krud Kutter. 20 pumps with your grease gun and call it good. If you are covered in goo again in a month then yes, you may have a problem. In a year, no.
Old Aug 10, 2008 | 02:08 PM
TheBelly's Avatar
OK, land rover swivel goo came in, and I installed that.
All fluids are correct, to include transmission, transfers, steering, and washer. . . .
Still getting the crunching and creaking....
to review:
1995 Disco 1, auto, 115k miles, with a crunching/creaking noise coming while turning, but under power only. It is a repeatable fault.
Old Aug 10, 2008 | 04:39 PM
I would take it in and have your swivel ***** checked out.
aguison
Dec 17, 2014 01:41 PM
Miwo
Mar 16, 2011 02:01 PM
starcraft
Dec 5, 2007 04:08 PM
EASTLAND
Jul 30, 2007 05:47 PM
