D1 and power steering fluid
Old Sep 16, 2008 | 03:53 PM
Hare's Avatar
Default D1 and power steering fluid
Just replaced a ripped power steering hose so I was wondering what I should fill it back up with, ATF or Syn. power steering fluid?
Old Sep 16, 2008 | 04:08 PM
Hare's Avatar
Default RE: D1 and power steering fluid
Also, how many bottles should I buy? I want to try and have it up and running before I pick my wife up from school.
Old Sep 16, 2008 | 04:25 PM
Di's take ATF in the power steering system NOT power steering fluid. You can buy full synthetic ATF.
Dexron III is what it takes.
Old Sep 16, 2008 | 04:59 PM
Hare's Avatar
All I could find around here is Dexon IV. Called the closest dealership and they should it would work fine, now to find out.
Old Sep 16, 2008 | 05:03 PM
Yes it will work just fine. ATF is backwards compatible. Meaning Dexron 4 will work in a Dexron 1, 2 or 3 system.
Old Sep 16, 2008 | 07:00 PM
mattrickman's Avatar
why is it that they take ATF? (not questioning the validity of the answer.. just curious technically why)
thanks
matt
Old Sep 16, 2008 | 07:26 PM
I dont know why. But if you notice most imports use ATF in the power steering system. And it is usually the same ATF that is required for the transmission.
My wifes Volvo takes Mercon in the transmission, so does the power steering.
DII's take power steering fluid and DI's take ATF, I dont know why is the short answer.
jycsalas
Apr 17, 2009 02:21 AM
willlane
Nov 10, 2007 07:33 PM
jdelp
Oct 3, 2007 11:05 AM
discoken
Jul 4, 2007 05:29 PM
nanin
May 12, 2007 10:09 AM
