D2 Diagnostic Tools
Old Jan 12, 2015 | 03:01 PM
  #31
Hellojello74's Avatar
Originally Posted by 04duxlr
Apple sets the Bluetooth to only work with the band for headsets and hands free devices so you need to jailbreak it and install roqby to open up the Bluetooth to other devices. Then you can install dashcommand or some other app to use the elm327 adapter. My problem is that the device I want to use is an older iPod touch that can't run a newer iOS do I can't use the current apps.
I believe you can use the WIFI capable ones instead of Bluetooth, as most of the apps will recognize it that way.
Still doing research and will report back if I find anything different
I have not used app nor any products yet, just posting a starting place for info.
From one site thus far.
"iPhone/iPad has restriction on Bluetooth support (Basically iPhone/iPad/iPod requires BT data device to have a special Apple authentication chip which 99% of the BT adaptors don't have). In order to use standard Bluetooth devices in data mode you need to jailbreak your iPhone. You will also need a third party tool to manage the Bluetooth. "
Outdoor Apps In The Palm Of Your Hand
Old Jan 13, 2015 | 08:40 AM
  #32
slabrat's Avatar
Originally Posted by Micko
Side Question.
Just got my Elm327 in the mail today. Hooked it up to Torque on my my Moto x with no problems.
Can I leave the Elm plugged in to my Discovery fultime?
I leave mine plugged in all the time, Unless I'm going to leave it sit for a couple of weeks or more.
Instead of having someone start it every few days I read to disconnect the negative post on the battery while gone. Not sure why the negative post?.
Anyway
But yea I leave my ELM plugged in all the time. I need to boot the phone occasionally so the bluetooth doesn't hang.
Price is down $12 bucks? wow I gave $35 for mine on Amazon but it was year before last. May be something better out there now.
Old May 19, 2015 | 05:30 AM
  #33
Georgebulldog's Avatar
Ok, so what am I doing wrong......just got my OBDII tool today and plugged it in and turned on Torque on my phone, but it won't read the ECU. My phone finds the Bluetooth connection to the scanner, but it won't link to the ECU. Checked with my wife car (plug and play) and it works fine.
Do I need to configure something different on the discovery?
Help.
Oh, new issue found tonight, I have a water coolant leak. Gonna have fun finding where that's coming from, I fear the radiator......
Old May 19, 2015 | 12:04 PM
  #34
acamato's Avatar
Help.
You could have an issue with the BCM to OBDII port header. I had an issue with corroded headers behind the blower motor. One of the headers fed the OBDII port.
https://landroverforums.com/forum/di...il-data-58201/
https://landroverforums.com/forum/di...-repair-57435/
Enrique5
Jun 13, 2014 03:43 PM
jafir
Jan 11, 2014 11:28 AM
Kalev
Nov 14, 2013 08:36 PM
DonRW2007
Apr 1, 2011 10:43 AM
jason0595
Aug 27, 2009 10:26 AM
