D2 idler puller (70mm) broke, threads seem stripped or is there a nut I'm missing?
Old Apr 12, 2017 | 07:10 AM
Manbeer's Avatar
Default D2 idler puller (70mm) broke, threads seem stripped or is there a nut I'm missing?
Went to buy a D1 the other night and was on the highway, and noticed my battery light turn on, so I went to pull over and the steering was heavy. At that point I knew I lost the belt. Luckily the entire process was like 15 seconds so I didn't overheat. Anyway, the small idler pulley to the right of the alternator (not the one with the arm) pooped out its bearing. I picked up a new one and went to install it but as soon as I feel any snug-Ness it stops grabbing and comes loose. I'm not sure if the threads are damaged somehow (not sure as it took a decent amount of force to get the old one out and seemed ok) or if there is a nut that goes behind it to hold. Any advice is appreciated as I still have it on the side of the highway and would rather not trailer it home
Old Apr 12, 2017 | 07:58 AM
abran's Avatar
no nut. You need a new bracket.
Old Apr 12, 2017 | 08:19 AM
Manbeer's Avatar
Thanks, is is a major pain to install and would I be better off just trying to heli coil it?
Old Apr 12, 2017 | 09:46 AM
abran's Avatar
Not too bad. You have to remove the alternator, unbolt the ground, unbolt the heater core hard pipes, remove belt, and remove the 2 pulleys.
Old Apr 12, 2017 | 09:50 AM
robert.juric's Avatar
The coolant elbow into the lower intake has a brace bolted to the alt bracket. It's possible you could work around that though.
Old Apr 12, 2017 | 04:56 PM
Manbeer's Avatar
Thanks for the replies, I'm trailering it back tomorrow and am probably just going to pull the radiator and helicoil it. The one caveat- I only have sae sizes so it means that I will have to match up the next size American bolt. Should throw the next person that services it for a loop
carlos84
Apr 12, 2017 09:43 AM
sayeedA
Feb 25, 2012 12:35 AM
acsink
May 31, 2011 08:38 AM
Rover Chris
Feb 13, 2011 12:03 PM
apcollin
Sep 29, 2008 07:24 PM
