Dazed and Confused
Old Sep 5, 2017 | 05:25 PM
JEFIII's Avatar
Default Dazed and Confused
My 2004 SE has a problem with the stock electric cooling fan. It comes on at cold start in the morning for about 30 seconds and then that's it. It does not come on when the AC is on nor does it come on at any other time. I live in SC so it has been hot and it should have come on. I have checked all the fuses and the relay and they are all fine, I even checked using another ECU. My Ultra Scan tells me the temperature is registering, so I am at a loss.
Could the fan not be picking up a signal from a sensor or two? Is there something I'm missing? Any help at all would be much appreciated.
Old Sep 5, 2017 | 05:31 PM
Alex_M's Avatar
The electric fan is just an auxiliary fan. It doesn't come on until the engine hits 212 degrees, which you should never see if you've got your cooling system set up right.
Old Sep 5, 2017 | 05:40 PM
abran's Avatar
You sure it's not your SAI pump coming on in the morning?
Old Sep 5, 2017 | 06:20 PM
dtmbinb's Avatar
It also runs with the a.c. on if it's above 83f outside.
Old Sep 5, 2017 | 07:21 PM
Red5's Avatar
^This^
I hear the SAI pump every morning ('80s era dust buster) but have never noticed the electric fan from inside the truck. I verified though that it does come on when the compressor is spinning.
marshman442
Jun 18, 2011 02:31 PM
Jason_B
Mar 18, 2011 08:54 AM
xb70valkarye
Feb 27, 2009 02:13 AM
crownaviation
Feb 22, 2008 10:01 AM
EL GALLO
Freelander
Sep 27, 2007 10:27 PM
