Differential to axle housing gasket?
Old Jan 2, 2021 | 11:13 AM
CameraDan's Avatar
Default Differential to axle housing gasket?
Is there a gasket for the differential? I'm swapping my differential to a new axle housing, and I'd like to put the proper gasket in there. I've found part diagrams that show a gasket, but don't list the part number... Anybody here know it? Do I have to custom cut something?
Rear axle diagram (part #9 here)
I've also found threads recommending Hylomar 101. Hylomar is not readily available in Canada, and I'd rather not wait for it to ship from Europe if I don't have to. Any alternative recommendations?
Thanks!
Old Jan 2, 2021 | 12:56 PM
The Deputy's Avatar
Don't remember there being a gasket on the Dll...if memory serves me right...it just had an adhesive. The Defender, Dl use a gasket, which is the axle you have pictured...that is not a Dll axle housing, hubs are wrong.
There are plenty of gasket making adhesives that would do the job. Just talk to your local parts store rep.
Old Jan 2, 2021 | 02:06 PM
SundayFunday's Avatar
clean both mating surfaces. Use good quality gasket maker.
Old Jan 2, 2021 | 02:55 PM
Alex_M's Avatar
Yep, a little RTV is all you need. Generally I get Ultra Grey RTV because it works pretty well with most everything.
Old Jan 2, 2021 | 06:08 PM
The Deputy's Avatar
Usually, my go-to gasket adhesive/maker is ultra gray prematex, especially for aluminum surfaces...but for axle housings...
https://www.permatex.com/products/ga...-gasket-maker/
Holds up better to rear end dope.
mwohl
Jul 10, 2013 10:42 AM
discovery 1
Feb 22, 2013 06:20 PM
nadylime
Apr 27, 2012 01:05 AM
Trickymonk
Apr 5, 2012 10:00 AM
Travelor
Jul 8, 2011 09:58 AM
