Disco SAI sounds like idling motorboat
Old Aug 11, 2014 | 02:00 PM
dparham's Avatar
Default Disco SAI sounds like idling motorboat
So this is a problem Ive had for awhile... I eventually just unplugged the vacuum canister to the SAI and that stopped but I through a few codes before all this... mainly O2 codes... * changing out faulty O2 and cleaning connectors when engine cools down... now back to SAI .... my pump doesn't sound bad... but I get this odd sound... when everything is plugged up properly, I get this sound at idle and gets faster as engine revs up... it sound like standing over a motorboat listening the the blablbablababalbalbalba sound that comes out of the water at the prop... anyone her this?? Id have posted earlier but I just could not articulate this sound in typing but I just thought today it sounded like that... maybe that makes sense? and if I unplug the passenger side vac line to that canister ( tiny vac line on both sides) the sound goes away.... my current code lineup is :
0135
0155
0150
0174
0134
0305
also had
1414
1417
1319 but they have gone away... for now lol
I did get a 0154 once too... and had a pending 1129 once...but Im fiddled with things since that and I don't see it anymore...
I know most are related to an O2 sensor which ill replace today but
Old Aug 11, 2014 | 02:58 PM
schwaggy's Avatar
You replaced/looked at your SAI Solenoid?
Old Aug 18, 2014 | 11:55 AM
dparham's Avatar
I looked at it but didn't replace it... I don't see any leaks from it ... how would I test it?
Old Aug 18, 2014 | 02:03 PM
schwaggy's Avatar
It was cheap enough that I decided to just risk it. My SAI sounded like an exhaust leak and I changed the solenoid and it quieted down.
Old Aug 18, 2014 | 02:04 PM
dparham's Avatar
hmmmmm Im going to do that just for spits n giggles... maybe it will help... shouldnt hurt!!
Old Aug 21, 2014 | 07:05 AM
dparham's Avatar
one thing I have noticed is that on passenger side O2 readings (USA) on my ultraguage Im getting 0.00 while SAI pump is on in initial morning startup for about 30 seconds... I also have open loop and throw codes 134-155 .. after 30 seconds all is well SAI goes off and loop closes and that O2 sensor start switching normally ...
Old Aug 21, 2014 | 09:26 AM
Dave03S's Avatar
That is the sound of exhaust backflowing from the engine into your SAI system.
Think about how that could happen for a moment.
It could only be a few things... Like the solenoid not closing the SAI valves and allowing two way air flow... Or the SAI valves getting gummed up and not opening/closing properly...
Usually the solenoid.
Old Aug 21, 2014 | 10:13 AM
dparham's Avatar
Thats what Im thinking... Im sure its an old part anyway so I ordered a new one... even though I don't get that code except once... maybe its just slightly functional just enough not to throw codes but occasionally....
jdill732
Apr 2, 2011 08:57 PM
jcrosby
Sep 17, 2009 04:20 PM
LRXD
Sep 13, 2006 02:24 PM
jmerrill
Mar 5, 2006 01:38 PM
Rovercountry
Oct 7, 2005 09:00 PM
