Disco2 Purge Valve Ticking
Old Nov 26, 2011 | 04:41 PM
philnewell's Avatar
Default Disco2 Purge Valve Ticking
My Purge valve on my Disco 2 (182K miles) is ticking, sometime it does not tick, sometimes it ticks at let's say 1x speed, sometime it ticks at 2X speed.
First: I assume it should not tick at all, is the purge valve faulty or is something else making the purge valve tick?
Coincidentally I have fault codes for left side SAI leak, I also have the SAI start running when I pull up at a stop light and site there for a while. Based on what I read I think this is because the SAI passive test was unsuccsessful.
Is it possible that the coputer is trying to do a passive SAI test and that cuases the ticking?
New purge valve is $65 so not a major expense, but I don't see any reason to change something if it ain't broke.
Any thoughts?
Old Nov 27, 2011 | 09:28 AM
Do you have a fault code for the purge valve, if not I am pretty sure it is just doing it's thing and it can be intermitent.
Old Nov 27, 2011 | 11:48 AM
philnewell's Avatar
No, no codes associated with the purge valve, the codes I have are SAI leak codes. Waiting on the SAI relay to see if that helps, but I suspect I have an SAI solonoid valve leaking.
Thanks for your help.
Old Nov 27, 2011 | 01:26 PM
hilltoppersx's Avatar
You would have an evap code if the purge was malfunctioning.
Old Nov 27, 2011 | 01:56 PM
Maybe it is also an oil pump tick..... might want to do a mechanical PSI test. Murphy's Law says you can have both.
Humdinger
Oct 18, 2016 05:05 PM
austinlandroverbill
Apr 1, 2015 06:26 PM
john65b
Oct 10, 2013 05:00 PM
rsr50
May 6, 2008 10:55 PM
BuckMontecristo
Jul 27, 2006 10:19 AM
