Discovery II will crank but won't start
Old Aug 12, 2006 | 04:41 PM
jrsactown's Avatar
3rd Gear
Default Discovery II will crank but won't start
Would the distribution cable cause a spark when cranking, if you put a screw driver by it? I tried replacing the fuel pump, I checked voltage to the fuel pump it seems to be okay but I don't see a spark.
Old Aug 12, 2006 | 06:24 PM
rinmud's Avatar
Default RE: Discovery II will crank but won't start
when you crank it does the check engine light go out????
Old Aug 14, 2006 | 02:13 PM
jrsactown's Avatar
3rd Gear
It turns on when I crank it. I first thought it was the fuel pump but I changed it out and it didn't work... so that's when I tested to see if there was a spark and there wasn't... So I changed out the distributor and it still won't turn on. I really have no idea what's wrong with it... About a month ago the SRS light started to come on, I'm not sure if that has anything to do with it...
Old Aug 14, 2006 | 07:35 PM
Landzu's Avatar
The fuel pump cut off will also kill the electric out put to
the coil pack on my 96.
I'm not sure if it works the same way on the LR's with distributor's.
Mike
Old Aug 17, 2006 | 12:45 PM
jrsactown's Avatar
3rd Gear
Thank you Mike, it was the crank sensor. I owe you big time!
Old Aug 17, 2006 | 07:44 PM
ORIGINAL: jrsactown
No problem, glad you didn't need all those expensive parts.
Mike
Disco Alan
Nov 21, 2014 09:21 AM
Jessicajw
Aug 25, 2014 10:30 AM
mattburn81
May 28, 2013 06:28 AM
dmatranga
Feb 5, 2013 12:27 AM
