DIY Suspension Lift - Anyone done it?
Old Nov 14, 2017 | 09:04 AM
Alex_M's Avatar
Bronco springs only lift 1". I've seen one actual report of someone using bronco springs in the front of their Disco and they used 4.5" lift springs to get 5.5" of lift.
Old Nov 14, 2017 | 12:34 PM
elboy0712's Avatar
ZG thank you. You are partially correct. I did specify that I went look for OME in particular, however im open to seeing data on any pre formed lift kits. I think with that data we can do it ourselves with other brands.
Old Nov 14, 2017 | 01:07 PM
ZGPhoto's Avatar
My comment was only a remark at you wanting to use springs, rather than spacers. Springs are the correct way to go
Old Nov 14, 2017 | 05:29 PM
elboy0712's Avatar
Ah gotcha. I think there are arguments for both depending on your goals.
Old Apr 19, 2018 | 12:05 AM
snowmansgarage's Avatar
Originally Posted by Alex_M
Ok, so here's what I've got. I just ordered myself a set of springs to replace my rear springs/blocks. They are MOOG-580; it says they're for a Caprice. Looking at lengths and spring rates, they're the same spring rate as Terrafirma MD springs except they're 1-3/4"~ taller. That should mean that over stock springs I'd estimate they lift ~3"; maybe 3.5". We'll see when they come in. They should also have a good spring rate for flexibility.
So with those in the rear, move the factory rear springs to the front, and maybe different spring plates in the rear for a fine adjustment, That should sit a person at 3"-3.5" of lift for $62 shipped.
Add in chopping and re-welding the front shock towers shorter which is free if you can weld, and either longer shocks or welded on shock extension tabs for the rear, that's a real cheap lift.
Will update with how the springs fit.
Did you ever install these springs?
Old Apr 19, 2018 | 06:38 AM
Alex_M's Avatar
Unfortunately no. The eBay seller I bought from sent me a giant bearing instead of the springs. Also I ended up going out and measuring the spring diameter on a set of factory springs I had. They were not the diameter of Bronco springs, which is what I was going off of because if the guy on Dweb or maybe Pirate 4x4 that claimed to use Bronco springs for a lift.
My plan now is to get a set of 3" Disco 1/RRC rear springs and keep the stock rear springs in the front. That will be a while though.
Xrover
Jun 5, 2023 11:18 PM
glassman66
Jul 17, 2012 08:31 AM
GamecockRover
Jul 16, 2012 02:00 PM
Emperor_MA
Jun 15, 2011 11:21 AM
kfx4001442
May 18, 2008 09:50 PM
