Does the D1 front wiper arm fit a D2
Old Apr 12, 2018 | 06:01 AM
austinlandroverbill's Avatar
And the right and left arms are the same?
Old Apr 12, 2018 | 06:02 AM
CollieRover's Avatar
Just did the Atlantic British Kit. Great product.
Old Apr 12, 2018 | 06:20 AM
mollusc's Avatar
The D1 rear arm doesn't have the washer nozzle in it.
Old Apr 12, 2018 | 07:02 AM
Sixpack577's Avatar
Yes
D1 take standard blades
D2 take stupid D2 only clips, that hold D2 only blades.
$16 for new D1 wiper blades is much better that $60+ for D2 blades.
And the D1 kit, arms, bolts, bolt caps and blades is only $60.
The D1 blade clears better too.
It's worth doing.
Old Apr 12, 2018 | 07:50 AM
OverRover's Avatar
Yes, the part #: DKB102710 is the same for both sides. Just do this "mod" you will be very glad you did!
Old Apr 12, 2018 | 08:37 AM
OffroadFrance's Avatar
Yep, they fit perfectly, I dumped the 2003 D2 arms and run with D1 arms, much better range of blades. Also you can fit silicon aero type blades.
Old Apr 12, 2018 | 10:26 AM
Dave03S's Avatar
I did this mod with the Lucky 8 arms hoping for more pressure on the windscreen. Did not get that though... still blades are now cheap enough to find the ones that work best.
With the old blades I would get snow and slush freezing up on the blade and not enough pressure to clear it if snow was coming down heavy.
The Icon blades work fine in rain but I don't think i would get enough pressure out of those either so I'm back to blades with braces in the arm.
aoakley
Jul 20, 2017 11:49 AM
imike1007
Jul 27, 2012 07:39 PM
AuZZZie
Nov 29, 2011 06:19 PM
Disco Mike
May 4, 2011 07:08 PM
x1124x
Aug 27, 2009 06:32 PM
