Does D2 Gas Engine have a fuel filter?
Old Jul 13, 2017 | 05:06 PM
OverRover's Avatar
Originally Posted by number9
FYI,
There is a filter but located within the pump assembly housing. There is no LR PN for the filter and no reference for replacing if that's even possible. A replacement pump should contain a new filter.
+1 . But give me an external inline fuel filter any day.
Old Jul 13, 2017 | 07:44 PM
JUKE179r's Avatar
So if the fuel filter does get clogged, go buy a new fuel pump? Great...
Old Jul 13, 2017 | 09:52 PM
Alex_M's Avatar
Or just remove it and put in an in line.
Old Jul 14, 2017 | 06:37 PM
number9's Avatar
Good point and as you would likely do if the only the pump in the pump assembly were to be replaced. Have not had to deal with those issues yet and did just knock on wood.
Old Jul 18, 2017 | 03:43 PM
Motorhead1's Avatar
Originally Posted by Motorhead1
Land Rover's theory for not adding any external fuel filter to the D2, was to reduce any flow reduction/restriction so fuel pump life would be long. Heat is what kills in tank fuel pumps, and when people run them with old cloggy fuel filters, that causes heat and reduced cool fuel flow back through the pump. If anyone wants to see really cool fuel pump tech, look at the LR3 pump, it circulates fuel directly from the tank to keep itself cool at all times, even if you have a restriction down line I suppose....
After "learning/understanding" more about the fuel pump in this thread, (thanks everyone), I totally take back this bad info. I did read this "theory" somewhere.....bad info.
Old Jul 19, 2017 | 12:05 AM
OffroadFrance's Avatar
FYI,
X1 ........... unlike diesel fuel where there is lots of water and condensation, petrol SHOULD have none in theory, so the primary pump filter is the only screening of petrol.
PS: If anyone decides to add another secondary petrol filter after the pump ensure it's a large one similar to the TD5 diesel filter and change it every other oil service or annually.
me 2
Jul 5, 2012 07:40 AM
nelsontod
May 18, 2012 12:20 PM
ryant06
Jul 25, 2010 11:35 PM
Danny Lee 97 Disco
Apr 5, 2010 12:57 PM
rravenn13
Jul 31, 2007 04:39 PM
