Door lock/actuator ??? Door key won't turn cylinder
Old Nov 26, 2014 | 12:43 PM
kristofferzen's Avatar
Default Door lock/actuator ??? Door key won't turn cylinder
I put the key into the outer door lock and is does not budge once it
It placed in cylinder/outer door lock.
Do I need to replace the actuator or something else?
The door will lock from the inside of the car and will lock when I press the door
Lock mechanism in the dashboard area.
This is the drivers side door lock.
Thanks!
Can anyone recommend a good place to find a repalcement
Lock/actuator if that is the case?
Thanks!
Old Nov 26, 2014 | 02:03 PM
abran's Avatar
Sounds like you need a door lock pin.
Some guys on dweb have dabbed them using a large nail. Can't remember what size though. Check out discoweb.
Old Nov 26, 2014 | 02:05 PM
abran's Avatar
Here is one for $20
http://wheeltrendz.com/LAND-ROVER-FRONT-LEFT-LH-DRIVER-DOOR-HANDLE-PIN-DISCOVERY-II-CXB103030H
Old Dec 6, 2014 | 08:14 PM
Mp1976's Avatar
8th Gear
Default Fixed mine
Pulled my handle out found at the end of the cylinder the last tumbler was broken and in the way not allowing the key all the way in. I pulled it out of the cylinder. Now working
Old Sep 10, 2015 | 12:11 PM
hokkabaz's Avatar
this is an old post, I hope you are still an active member hahaha
would you be able to find a link or help me to find the page on that site? i am having the same problem now and I couldnt find any information anywhere except your post
Old Sep 10, 2015 | 02:11 PM
abran's Avatar
Not exactly what you were looking for, but should help:
2004 - Door Actuator - Land Rover Forums : Land Rover and Range Rover Forum
Take the broken pin to the hardware store and match up a nail that has the same circumference. Then modify it to match the broken pin.
Or, Dish out $85 for the Cadillac of door pins:
http://www.jewellamberoil.com/sales/...roducts_id=297
silar
Mar 3, 2021 07:21 AM
Tricked306
Dec 6, 2018 11:37 AM
toad2
Jan 17, 2014 09:19 PM
dpaller
Jun 13, 2013 12:43 AM
