Drain Plug next to the Oil Filter? Leaking?! What's it called?
Old Apr 7, 2018 | 11:44 AM
Alex_M's Avatar
Also on the front cover. There are 2 plugs on the side.
Old Apr 7, 2018 | 11:45 AM
Best4x4's Avatar
No not in the gauge location, On the timing cover you have two ports on the upper side (one is the oil pressure switch), and the other is just a plug. Down by the Oil Filter Housing is where one oil cooler line connects. The other connection is on the bottom of the timing cover towards the front.
Old Apr 7, 2018 | 11:47 AM
Sixpack577's Avatar
Thank you sir.
I'll take another look at the cover.
Old Apr 7, 2018 | 12:04 PM
JettsRover's Avatar
Heres's an interesting follow up: It would seem my oil leak has stopped. Which is good news. What is GREAT news is that the chirping I was getting at start-up is now also gone! It had started about the same time I had replaced the power steering pump, so I had assumed that was the issue.
themdg
Jan 25, 2015 01:52 AM
kimsd
Sep 25, 2013 01:02 PM
real_tea
Feb 15, 2013 10:00 AM
1ozeme
May 17, 2010 03:11 PM
chiasurf
Dec 29, 2008 11:25 AM
